Onenote download trial key features.
What are the one note download trial key features that I can still use even when my trial period of 60 days is over?
The only key features that you can utilize with your expired OneNote trial version are to open and view your notebooks. Creating and editing notes are disabled. To enable the other key features, you will have to buy the full version to get the product key and continue using OneNote.
You don’t need to install OneNote again after the purchase.
Hi Annelforth,
I have reviewed your issue; you are looking for one note trial version again, But you cannot use again trail version when once it's expired. It is create a registry files. This is non-removable.
So you need to purchase the full version of one note. You can purchase the full version of one note from the below mentioned link:
https://www.microsoft.com/store/msusa/en_US/DisplayHomePage
I wish this solution will be helpful. Thanks!
Best,
Fenster Maxine
