JamesSmith
Posted on - 07/25/2011
There has been an error message which remains on the screen as soon as I start my PC and logging into my account.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:Program FilesTall EmuOnline Armoroasrv.exe
R6025
-pure virtual function call
OK
This is one of my office desktops which has Windows XP Professional SP 3 installed on it.
Since we had to install Online Armor as official security software , I had installed the AV+ and updated it to the latest build 1.1.1.814. There were no activities performed after I logged into my desktop.
I haven’t been having this error message until I installed Online Armor software on my machine. There are 2 other users using the same PC and they do not get this error message on their desktop.
Is this anything related to my account? My user account is the one which has admin access, would that be a reason for this error message?
henjov22
Online Armor Runtime Library error message on Windows
Hi good day in this kind of issue your Visual C++ installing corrupt you my download again the Microsoft visual C++ and it into your computer. After finishing installing the visual C++ and then open your game and you can play it now.
Take care hope you can do it.
Henjov22
Its look like that the Online Armor has corrupted your C++ runtime. You should try reinstalling the latest version of it from Microsoft's website. It will be labeled as C++ runtime redistribute able 2005. Download it from their website and install it on your computer and you should be good to go. I hope you find the solution.
Peter franklin
Dear James,
First of all this error has nothing to do with your admin account.
Oasrv.exe error is an application error used to appear because Oasrv.exe one of the non-system processes originates from software installation (Online Armor in your case).
They are capable of damaging your PC functionality very easily.
This has potentially damaged your C++ library and therefore you need to download your C++ again and one such ready link is here
You must know your problem well to solve it.
Enjoy!
Hi James,
This type of error, it doesn’t have anything to do with the account type that you are using.
The runtime error returned (pure virtual function) is caused when the application (Online Armor) indirectly calls a pure virtual function when the context is not valid. This in general is detected only at run-time, but depends on how the application code was written.
You can try to fix this reinstalling the Online Armor using your account.
Best regards,
Aabel
