Online Articles on Windows Mobile Office repair
I would like to have online articles on Windows Mobile Office repair and on restoring the Windows Mobile device in case of repair.
Hello Stephen Heris,
To repair the mobile version of Microsoft office there are 4 simple steps to do it. If this causes any damage to your mobile, you can restore these again by following these steps.
These steps are:
1. Restarting your phone
2. Updating your phone
3. Reset and restoring your phone
4. Roll back your phone.
Details can be founded in the following link.
Hello Stephen,
Pocket Mechanic software is one of the best application you can use to repair your Windows mobile office. You need to download this application from  https://pocket-mechanic.en.softonic.com/pocketpc . Install this application on your device. Then, you will be able to do so many repairs and maintenance on it.
You can restore your windows mobile device to default setting using an application on your device called clear storage. Go to settings>System tab.
Enter the default code and press yes. This will restore your device. For your information, you may lose previous applications installed in your device.Â
I hope this gives a guide.Â
Alfaro.
