Young Hern
10 points
Posted on - 03/20/2013
Hi Friends, I need to have an online Cover PDF Maker, that will convert me the cover file (the file is in JPEG format) into corresponding PDF. Please suggest me the best online converter that will help me to convert the JPEG file without any quality issue. The size of the JPEG is around 1.07 MB.
Online Cover PDF Maker (JPEG to PDF)
Hi Young Hern,
Here the size of a JPEG file is not a matter but if your image resolution is the medium then it is good. There are many websites that will provide you free service for creating a JPEG file to PDF file. Just you should go to Google and search for “JPEG to PDF file online Convert”. Then there you must get some website address where you can convert your file for free. So, find a website and convert your file. To consume your time I am going to give a link where you can convert your file for free. I suggest you that you should go to Google to find a converter because some time this link cannot be work.
Here the link: https://www.convert-jpg-to-pdf.net/
Best of luck
There are a lot of free things out on the internet. So it is so easy to find over internet our every essential. So according to your asking I am giving you couple of website address which are good.
1. Try with is one: https://www.convert-jpg-to-pdf.net/
2. Then another one you can try is: http://convertonlinefree.com/ImageToPDFEN.aspx
3. Another one is: http://convertjpgpdf.net/, but it has limitation which is filed may not larger than 8 GB.
I hope this is informative to you. Good luck.
