Online games with low file size for playing offline
My son is so crazy about online games, and uses internet for playing games, I thought of downloading the same, so that he can play offline. Can anyone list few online games with low file size.
Hi Downsnieves,
Your query is really easy to solve! The low file size games from the internet are quite plenty, especially the flash games, it will depend on the low size that you require, in order to get the low file size games from the internet, you can go to this website; BRIZY (http://www.brizy.com), once you get to the website, you can create an account in order to download the game, or you can also go the website; Onlineflashgames (www.onlineflashgames.com}, Dosgames (www.dosgames.com).
Also from Freewarefiles (www.freewarefiles.com). You will get very good games which are suitable for children and good to play.
I hope this solves your query.
Notifications
