sherrywcarr
30 points
Posted on - 05/02/2013
I have a problem with regards to the pdf file I recently downloaded, the document is in that format. The problem occurs when it comes to online pdf form filling, I could not edit directly to it and when I try to do it using MS Word, I inserted the PDF file into the word doc and it comes out faded? There might be something wrong with the process as how I do? Does anyone have an inkling as to how it is done?
Online PDF form filling process so as it will come out properly
Hello Sherrywcarr,
If you want to edit the PDF documents then you need to download the PDF software. You can download Foxit reader for that. After that when you open the web page containing the PDF. Then you need to download it and after that you need to fill it using that software. You can also download the websites as PDF format. All you need is to press "CTRL+P" After that save the file instead of printing.
There are two things here that you should know before anything else. First, you cannot fill out the information directly from a downloaded PDF file. Second, copying the information from the downloaded PDF file to Microsoft Word may do it but as you say it is faded.
In order for you to resolve this issue, you will need to have a software that will convert your PDF file to Microsoft Word file first. You can download a specific software for this or if it is too much of a trouble for you to download one, you can always use the online converter. Here are some of these software:
Online Converter:
Free PDF Convert – this online converter is amazing since it will not just allow you to convert your PDFs to Word file, it lets you do the other way around, too. Additionally, it will also allow you to convert other file formats to the file format that you want. To check out other file formats that they support, click HERE. You can use this if that would be the only thing you need to convert. If there are numerous files you wish to convert, you will need to create a user account but they impose membership fee.
PDF to Word – This one is 14 days free so you can convert any files you want during this entire time. However, just like the first one, you will also need to pay after 14 days is up to continue using the service.
PDF Online – this is absolutely free and will not require you to enter your email address just like the two above. It also comes with Word to PDF. I mentioned this since you will need to convert later your Word file back to PDF after you are done filling out the information needed.
Free Downloads:
VeryPDF – as mentioned before, if you will need to download numerous PDF files that you will need to fill out forms in it, the best answer for that are PDF converter software. This one is the most popular
List of Free PDF to Word Converters – check out this site for more converters you can choose from.
Once converted, you will now be able to enter the needed information on the form. When you are done, it is time to convert the Word file to PDF back. Here are some:
I hope this answers your issue.
