Online Portal that search motherboard driver automatically
Hi Techyv Friends,
I don’t know the motherboard model of my system, I would like to  search motherboard driver automatically, so that it recognizes the motherboard and downloads and installs the driver automatically. Please do the needful for providing any such online portal, who is having this feature.
Thanks,
Anna W Brown
Best Answer by Fletcher Hoss
Answered By 0 points N/A #198397
If you do not want to download and install the motherboard driver, you can install it automatically from the device manager. Just make sure that your computer has access to internet and then go to Computer and click to open, and then click on System Properties, and then Device Manager. There you will see a number of drivers and those that haven't been installed will be having a yellow question mark on them. Locate the motherboard driver, right click on it and then choose Update Driver Software, and then choose "Search automatically for updated driver software".
Fletcher Hoss
Answered By 0 points N/A #133198
Hi Anna. First you must know the motherboard model by going to start-up and find RUN. Then type "dxdiag" and enter to know the specs of your computer. After knowing the specs of your computer, try to search the motherboard driver for any type of browser. Just type the model of the computer and try to find or purchase a good licensed software that could help you to find the motherboard driver that is really compatible. Always remember the compatibility issue of any specs of the computer.
