jobhelle03
Posted on - 10/10/2011
I was trying to use my other laptop yesterday but whenever i try to open it only blue screen appears and it freezes there. It's loading OS. I haven't add/change any HW or SW in it. Please help! What do I need to do? Thanks.
Choumen
5 points
Only blue screen appears nothing else
The blue screen of death, also known as the blue screen of doom or simply blue screen, is one of the most notorious error messages in Windows based operating systems. To fix blue screen errors, you can safely assume that there’s something going seriously wrong in your operating system. Unfortunately for us, and even the highest trained computer technicians, fixing the blue screen of death isn’t always as simple as we’d like it to be, and it can take an obscure amount of PC knowledge to get to the root of the problem. 90% registry cleaner can fix the blue screen so click here and you will get details to solve your problem.
A Blue Screen error will come up on the Windows preload when these models boot
with "Compatible" mode instead of "AHCI" that is modified from the BIOS Setup/
Config/Serial SATA menu. Stay "Compatible" mode when you boot Windows preload.
Go to BIOS setup Option, and resetup.
benson
Hey Jobhelle03,
Start your computer in safe mode, to do this, Press F8 and use the arrow keys to select safe mode, Press enter to boot.
In case this fails to work, You will have to re-install your windows vista and to do this, Get your windows vista installation disc, insert it in your computer and switch it off using the power switch, switch it on again and when booting press F8 and select to boot through a CD ROM.
Select the language and accept the terms and click next.
Next click custom and then select the drive plus the partition where you want to install windows vista. Click on formatting option (this means you will lose all the data on that partition). Click next.
Just follow the instructions and it will be done, the blue screen problem will be solved.
I have the same problem as the thread creator. I am very thankful for everyone for sharing their thoughts. I used the Windows Installation disc to fix this problem.
