O&O Launch Pad 3.0.107 support
I want a good software to launch all my O&O products via a single interface. I’ve just come to know about O&O Launch Pad 3.0.107. I need to know which applications does this tool detect and fire up.
Hi Elyssaguadalupe,
O&O LaunchPad is a very simple but standalone tool which allows you to launch ALL your O&O applications. It also allows you to INSTALL the O&O applications from scratch.
It fires up the following O&O applications:
AutoBackup, CleverCache, Defrag, DiskImage, DiskRecovery, DiskStat, DriveLED, PartitionManager,SafeErase,SSD Migration Kit.
See figure:
It uses about 13Mb ram, as such can be left running in the background.
Its main advantage is that, when you use several O&O tools, than this simple single, Launchpad can Install them from scratch, and you do not have to go to the O&O site to find various downloads, simply run the Launchpad and it will automatically download and run each required setup program.
Simply put, Launchpad is the best way to setup your new PC with the O&O products with a single click.
PT
Notifications
