I could no longer find the installer of Box2d-Editor online and when I search Google for the download link, all I am getting in the search result is the Physics open body editor. So I tried opening it, it has a lot of similarities with Box2d-Editor but there are a lot of new features and functionalities. So I am thinking, if this is an upgrade of Box2d-Editor, then they just made a major overhauling of the software. Can anybody confirm this?
Is open body editor the same as in Box2d-Editor
Hello Donal,
Both Open body editor and Box2d-Editor are applications that perform same functionalities, but Box2d-Editorseems to be more advanced, or it has more features. Therefore, you cannot get Open Body readily will suggest that you just use Box2d-Editor for it will allow you to do what you could have done it Box2d-Editor.
Nicke
If you already searched, you should know that Physics Body Editor is also the previous Box2D-Editor. You can download it from the links below:
Download and Install Box2d-Editor 2.9.1
Download and Install Box2d-Editor 2.9.2
Here is a video tutorial on starting Physics Body Editor:
[video:http://www.youtube.com/watch?v=KASY91EiTXQ autoplay:0]
