Is open office vbs Windows supported?
I want to know if open office vbs windows supported. I used to use MS Office but I want to switch to Open office because it's for free. If so, are there bugs or issues?
Hello Dorothy,
Yes, Open office orgs supports Visual Basic. Heres the link to take a closer look at it.
Or you may consider the full feature of the latest open office org as well. Heres the link.
I should say that there could be bugs out there.
Microsoft's VB technology is updating fast and I'm pretty sure open office org team is doing their best to make open office org live with the completion.
Download latest open office org HERE.
Hope this helps you with your problem.
Hi there,
Yes indeed, Windows support Open Office but it is just for the 32 bit Operating System there’s been always a problem on 64 bit Operating System when it comes on installation process, there are issues about hanging and system crashing when it comes to the installation with the 64bit Operating System.
Hope it helps.
Notifications
