Open Portable VPN Installation Error
Can you solve this issue? I am receiving this error while installing an upgraded version of VPN, that is called portable VPN.
As you can view in the image given below, the error is regarding the VPN portable installation.
The files are not affected by virus or corrupt but still I receive this message while I install it.
Error by installing virtual network drivers. Retry?
Can anyone figure out what could possibly be  the error, that is interfering the installation process?
I thought that may be the installation file is corrupt.  So I downloaded another copy of the exe and tried to install it again but again I got the same error message in response.
So if someone knows what the error is, then please feel free to respond.
Best Answer by joicy
Answered By 0 points N/A #120479
Hi dear friends,
you are getting an error when you install / open VPN on your computer. I think you are doing some thing wrong while installing the software.
I  suggest you install the software carefully, the right way, then this problem will be solved.
You can follow these steps one by one and  correctly install it once again.
  1. First launch MSI installer and click Next button.
  2. Check the accept check box and read license agreement and click Next.
  3. Then choose location when install the program.
  4. It's ready for installation, just click install button and proceed install process.
  5. Wait for desktop client to install.
  6. Take some time to finish installation, then Click Finish button.
 Thanks
Answered By 0 points N/A #120480
  • If this problem occurs, "Error by installing virtual network driver. Retry?".
  • The cause might be that the login account, may not have administrative rights to run any installation. From this point one may need to select "No" and follow the Instructions, from this point.
  • Another option would be to check the memory space and also check for any registry errors when making changes to the system. It is highly recommended, when going through any un installation of software.
  • One other option is, try to increasing the permitted number of filter drivers in the registry.
