Hi dear,
I am Mobile Application developer and Develop these application in Java and for this purpose I am using NetBeans because it is best platform for such type of work. But from few days I am feeling this problem any one tell me its proper solution.
Open Projectt
           One or more projects do not have the target server set properly.
           Right-Click the project in the Projects window and choose.
           Resolve Missing Server Problem to set the target server.
           Do not show this message again.                                        Â
        Close
Thanks in Advance.
Open Project Problem In NetBeans
Hi Peter,
Open Projectt
        Close
So this was your error and as you said you are a developer. As far as I know all the developer has a solution when they are facing a problem. Will my suggestion about your problem. Is you did something wrong about your file or program. So I recommend that follow your instruction that instructed you by the computer. In that case we both know what your problem was. Just try to set the target server. This would help. Thanks,Â
