gmlaud
40 points
Posted on - 08/04/2011
I use PhotoShop in my work. however there are times that i have to edit certain pictures which i was able to save in .psd format. i only installed my PhotoShop application in my office PC, is there way for me to open and/or edit my .psd file in paint?
James20
5 points
Open a .psd (Photoshop) file in Paint application
Hi dear,
yes this is possible. When you do work in PhotoShop then you save that file in both first save it in PSD format because this is editable after it you save it in JPG, Gif format or other such type of format then you right click at that picture then there will appear one option which is edit option click at that option then it is automatically open in paint and then you can do work at that picture
If you want that PSD picture is directly open in Pain this is not possible because paint is not support PSD format for this purpose you can use other software that can support Adobe psd files such as Corel Draw.
Ok
