Jasika Jame
10 points
Posted on - 11/28/2012
Hello People,
My open source FTP client FileZilla has encountered a problem. Have a look at the error message below. It is indicating runtime error. Have you any idea of the error message of the application? How can I solve it? Please help.
Waiting for some solutions.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program C:program filesFilezillaFilezilla.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
Open source FTP client FileZilla has encountered a problem
Dear Jasika,
The error you have mentioned above, Microsoft Visual C++ Runtime Library Runtime Error!, is due to the fact that you are using an old operating system and Filezilla is not supported on that operating system. So, you need to upgrade to a newer operating system, like Windows 7 or Windows 8.
Runtime error or Runtime Library error is one of the most frequent errors that appears when running various computer applications. It is so annoying and sometimes it can cause problems from pop-up notification leading to an unexpected blue screen of death. Failed to contact Visual C++ Runtime library is the main reason why this error will occur. Reinstalling Visual C++ sometimes fixed this kind of error.
