Dear Techyv Users,
I need to know about, how open Tecdoc database file be exported to excel or csv formats. Is it possible to export so, If so, Please do the needful for providing me the step by step process of doing the same.
Thanks in Advance,
Floyd A Beverly
Open Tecdoc database file be exported to excel/csv
You need to use the TecDoc Data export software and that provides an easy access to download the data from one format to the other. Through this software the TecDoc software can easily be converted into the excel format. Thus we can easily convert the TecDoc export software quite easily into the excel format. You just need to download the software and click on the button from the menu provided. You can then call the excel sheet to any of the IDE environment like visual studio.
Waters Magner
