OpenAccess Assembly compile errors when building
10 points
Posted on - 02/21/2012
Hi.
We get an Open Access assembly in the result that mentions OA Q3 2011 (2011.3.1116.3). However, the 4.3 edition in the SF task is 2011.2.713.3. See screenshot below.
For the first time, I've noticed compile errors when trying to build. Usually it appears to assemble, but assembly binding is needed for the front-end to load.
Error:
Error List
Description File
485
Assembly 'AuthDB, Version=2011.12.5.1, Culture=neutral, PublicKeyToken=null' AuthDB.dll
uses 'Telerik.OpenAccess, Version=2011.3.1116.3, Culture=neutral,
PublicKeyToken=7ce17eeaf1d59342' which has a higher version than referenced
assembly 'Telerik.OpenAccess, Version=2011.2.713.3, Culture=neutral,
Description File
485
Is there any method to make these play gladly?
Need your help.
