Openbox error, fails to execute command for pipe-menu
Hello experts,
When I attempt to open any libre-office app from the “office” Openbox menu, I get The following error message. I tried many times to solve this problem but still have the same problem. I really need your help to fix this error message.
Failed to execute command for pipe-menu “cb-libreoffice-pipemenu”: Failed to execute child process “cb-libreoffice-pipemenu” (No such file or directory)
Openbox
Best Answer by Waters Magner
Answered By 0 points N/A #182253
Try this:
1. Right click then go to Settings > Openbox > GUI Menu Editor
2. Add your own lowriter and localc on the GUI Menu Editor
3. Save and exit. You should be able to launch the App now.
Answered By 5 points N/A #182254
I feel some step is missing. You have not been able to install the libraoffice properly. You need to reinstall it but keep in mind that some script is missing. Either you get the new installation DVD or you need to find the script that is missing. In that case, this problem will be solved definitely.
