Opening an internet gateway in mobile?
I cannot access my internet on my phone, a pop up word box  appears everytime. I attempted to browse the internet and it says "An error occurred while fetching the requested page". What will I do? Where should I go to access my internet.
Answered By 0 points N/A #99894
Hi! Luchie Anncassar,
What kind of phone are you using? Most of the mobile phones and  smart phones has a default browser installed to use for browsing.The Phone has dedicated and designed to work for mobile browsing. The error “An error occurred while fetching the requested page”.How to fix this? The answer varies of what type of phone you are using. I will post here the instructions but this only applies if you are using Blackberry phone.
You have to go into the options settings on the browser, go into Browser Configuration and make sure Hotspot Browser is selected.
Steps to Configure WiFi :
  1. Blackberry menu.
  2. Setup folder.
  3. Setup Wi-Fi icon.
  4. Scan for network, manually add network, push button setup and Wi-Fi Hotspot login.
  5. Manually Add SSID if Phone can’t detect Wi-Fi.
  6. Push button setup.
