Hello everyone. When I try to install or open Bridgit software services, an OpenSSL.exe error message shows and the services are not starting. Can anyone help me? Please.
Error Message on Starting Alpha5 No transforms that I am tuned in to. Mention that, I am using the latest one.
If I click OK, still I am able to open the application but I would like to end it. Need your help. Thanks.
OpenSSL.exe error message when installing Bridgit
Hello there. This problem of Bridgit occurs because the software is not able to generate the Secure Socket Layer certificate. Do not worry. This problem can be resolved. Update your Bridgit software to a version for example Bridgit 3.3. This installation will generate a 30 years valid SSL certificate and your problem will be resolved. And your alpha 5 problem is occurring because maybe you are running it on a 64 bit OS, run the program as 32 bit application. This is likely to solve the alpha 5's error, but it is recommended that you report about it to the Alpha software team explaining your matter and they will help you solve it clearly as they are very responsible to these matters and maybe you will get a quick response or a fix to this error through an updated version. Hope your problem gets solved soon. Best of Luck!
