Hello Guys, I have a problem regards with updating my OpenSUSE. Every time I update it this error appears and gives me no idea about what this error all about especially to the characters represented by this error, and of course I am not a technical person so I really don’t know how to fix this one. Can I fix this one by my self? Please send me a simple instruction how to solve this.
openSUSE Updater
kdesu(17907)/kdesu(kdelibs)
KDESu::KDEsuClient::command:
[/usr/srcpackages/BUILD/kdelibs-4.0.4/kdesu/client.cpp:196]no reply from daemon
OpenSUSE Updater-no reply from daemon.
Hi friend,
This error comes only at the time of updating OpenSUSE. These characters and commands can’t be described by anyone or any websites. But therefore I found a little help for solve this problem. First log in your pc with username and password and log in as a root user. Now check for new update and then find update as it recommended.
Then turn on automatic update and connect your pc with internet. It will automatically start updating OpenSUSE. I hope this time it will update without any error. Every application in Linux, there if you want to edit it you need to login as root user.
