Openvpn problem on my iPhone4
What software can I use to make OpenVPN work on my iPhone 4S? I am currently using OpenVPN on my Samsung Galaxy Ace without having any problems and I also want to try it on my iPhone 4.
If you want to use an OpenVPN, please try this very nice little app that can finally make you enjoy the Open VPN protocol, the OpenVPN which until now was not usable on the iPhone (only the L2TP, PPTP and IPSec were so far) This application is GuizmOVPN, it is compatible with iOS4. This application has been tested and reported to be working properly. The benefit of using OpenVPN is that a VPN offers much larger (some servers only allow the OpenVPN), it is more stable and there is less disconnections, it allows up to 2048 bit encryption (128 bit only PPTP) and it uses TCP and UDP port which are normally not blocked by the 3G operators and Wi-Fi hotspots. More info about GuizmOVPN on :http://www.guizmovpn.com/ You'll find full details for installation. You can have a free unlimited try for 7 days, then for periods of 5 minutes each time interrupted by breaks of 5 minutes. The cost for this application is 4.99 euro.
Thank you
