Opera add ons manager Software tutorials
Hi expert, I need opera add-ons manager Software. The operating system that I use is Windows XP. If you know please send a proper download link to download it. And send some helping tutorial explanations to use this software on possible way, Also please explain me the special features, the main advantages and disadvantages of using this software?
Best Answer by Sharon D Mickelson
Answered By 10 points N/A #163679
Hi Denise,
Opera add ons is the extension to add features and functionality to Opera. There are lots of add ons available for opera.
Go to Menu -> Extension -> Manage extension.You can change the settings for an extension.
By clicking the settings button on the right you can change setting for each extension.
Answered By 0 points N/A #163680
The best way to manage extensions in any browser, including Opera, is to do it by hand. Extensions are by their nature a way to customize the performance and appearance of Opera to your exact desires. This also requires a little bit of work in learning how to do it, but the payoff is immense. For example, you can install the "Chrome Extension Installer" by clicking this link (requires Opera Next 15 and above) and then install Chrome extensions from Chrome Web Store found on this link.
