Opera browser error code 2318
I was browsing with my opera 10.63 and everything was fine. Then I turned on my Automatic Updates for my system. NOTE: I’m using windows 7, after the updates and all that I checked my opera browser and it got upgraded to opera 11. When I opened my opera browser I got this error “error code 2318”. I have no idea how to fix this.
Please help me!
Best Answer by Robert_Williams
Answered By 10 points N/A #83434
Try this!
If you are getting trouble with the version of the Opera 11 then it will be better if you can just uninstall it by going in the Control Panel and then making the removal of the things there. After this you can go and install Opera 10.63 from the setup file that you have on your system. After doing this please turn off the automatic update on it. Else you will have this Opera 11 getting installed in your case again here. Please Check the Antivirus program that you have installed on your system and see if that is having no issue here with this. Make sure that you have the updated antivirus program running on your system there and see if that can help you with the situation of yours here. Perform the through scan on the system and see if you might have got caught with some malicious program here.
Good Luck!
Answered By 10 points N/A #83435
I have looked at your situation here and let me really tell you that there is really nothing that I can do here in this case. I am of the opinion that you might be getting the issue because of the know bugs that are there with the Opera 11 browser here. If you want you can get rid of the issue just by ignoring the update and working again with the error free Opera 10.63 version here. Please make the way for this step and let me know if I am correct here.
