Opera Browser not working on Nokia C2-01
I am using a Nokia C2-01 and installed Opera Mini Browser Version 6.5.0. But lately the Opera stopped working. I already updated to the latest version but it is still not working. What should I do?Â
Hello.
When you install opera mini browser it requires your mobile internet access to get installed completely.
Make sure that your mobile has a good internet connection and also internet access to all the applications in the mobile.
Check for the proper configuration settings.
Contact your service provider for internet settings.
Thank you.
Try to check on all the recent installation of Opera Mini on your file Manager and remove it all. And then try downloading again from this site: http://www.opera.com/mobile. Be sure to remove all of its components before proceeding with a clean installation. Maybe the version that you are trying to install are damaged or corrupt. Download the .jar file and then transfer it to your phone and then simply install it.
