Opera latest version Opera 27 doesnot working in my windows 8.1. It installed correctly but when I run it it get hanged. I tried to reinstall the browswe and also re installing the OS.But problem is same. Then I install the browser in windows 7 and this time the browser worked   But it doesn’t allows adobe flash player
points
Opera browser is not working properly
Windows 8.1 is one of the latest OS in the market. It comes with thousands of new improvements and new features that Opera might not be able to recognize and so giving this error.
If you’re trying to install the web installer, forget it because most of the time, the installation might be corrupted due to internet connection. Download Opera Offline. This is offline installer that will install the whole components of Opera.
According to Opera’s official site, their latest version is Opera 25. If you’re running Opera 27, it’s just a scam and so giving this error. Download the right installer and install Opera.
Opera is a Chrome-based browser. If you still have trouble, either you should use your Windows 7 or get the main browser, Google Chrome. Download Google Chrome.
Download Adobe Flash Player’s offline installer. Then, deploy it on your system. It’s compatible with Windows 8.1, so nothing to worry.
