Opera Error. anyone has a good heart please help me.
Need your solution,
I have this opera on my windows 7, in the first place this was running perfectly great but when I’m trying to load some codes on this, this error occurred I tried to solve it but i don’t know what to do. Please help.
Opera Error
Failed to load the Unicode compatibility layer OUniAnsi.DLL because:  The specified module could not be found.
        OK
Thanks in advance,
Best Answer by Bertha
Answered By 0 points N/A #127450
It means your file OUniAnsi.DLL was corrupt or missing.
To resolve this, you can download this OUniAnsi.DLL
file from here:
After download this file, click Start > Run
Type this command at Run Box
# To install the dll files, type: regsvr32 Ouniansi.dll
# To uninstall the dll files, type: regsvr32 -u Ouniansi.dll
Install Ouniansi.dll, if the error says your file is missing
Uninstall first Ouniansi.Dll if the error said file is corrupt.
After uninstall, then reinstall the file again. 🙂
Answered By 15 points N/A #127451
Hi.
It’s a simple error which will come when your ouniansi.dll file get corrupted.
So simple you have to download the ouniansi.dll. just write it on Google its easy search.
After you download it delete your older ouniansi.dll file with the help of RUN BOX.
To delete old one type regsvr32 –u Ouniansi.dll and then install new one by typing regsvr32 Ouniansi.dll
Your problem will get fixed.
