I have issue with Opera Browser and can’t fix it without getting your help or suggestion. The following error occurred while parsing data from the opera Link server. Thanks for any help.Â
Opera Link Status
An error occurred while parsing data from the Opera Link Server
Opera Link Status error has occurred
Hi William,
After browsing and figuring out the solution for this error. I found out that this error occurs because of the content blocker or the typed history. So perhaps you should disable the typed history as well as the content blocker. If the error still persists, uninstall the program and reinstall it again. I hope this will help you.
Martine Paul
