Opera mini browser error on Nokia mobile
Hi!
I use Nokia X3 for last one year. Recently I have updated the Opera Mini 6.0 to 6.1 but after updating the software I just frequently get an error message. I keep getting this message :"Error 533 java.io.10 Exception:Couldn't read from socket".
I'm just stuck right now. If anyone have a solution of this problem please reply me. I want to get rid of this problem?
Best Answer by oviwizy
Answered By 0 points N/A #96189
Remove the recent Opera Mini 6.1 and redownload  Opera Mini 6.0,is  suitable for your phone.
Answered By 0 points N/A #96190
 Hi! Nora Johnson,
 You have come to the right place. I have given a solution that can resolve your problem.
  1. Go to your Opera mini from your mobile and open the standby page.
  2. Go to the left-hand key and you can see a pop up menu will appear on the right-hand side.
  3. Scroll down the menu and go to the Settings.
  4. Then you have to change the connection by scrolling down the protocol.
  5. Then you have to prompt to download an Image for free and download it.
  6. If it will not work then uninstall the running version of opera mini and install a new one.
 I hope it will resolve your problem.
Answered By 0 points N/A #96191
Hello Johnson,
I understand your problem, you can find a solution easily. Firstly you can uninstall your recent opera mini software, Then go to:
http://www.opera.com/mobile
choose a specific version , Click on Nokia from menu list, then show another list select specific model, you will be see a link like this "Nokia X3.00". Click on this link. Based on testing performed by Opera Software, this device supports Opera Mini 6.1 and Opera Mini 4.3. Now you can download your supported opera mini software.
If it is not support your mobile, then you can make a format your mobile memory. Then try again.
Answered By 0 points N/A #96192
Dear mam, please use internet setting when you using opera mini or may be Opera mini 6.1 not supported  in your X3. So, please use previous version.
Thanks
