Hi. I have the 32 GB Sony Xperia S that has the Qualcomm MSM8260 Snapdragon chipset, Dual-core 1.5 GHz CPU, Adreno 220 GPU and Android OS Jelly Bean. I just installed the Opera Mini Next web browser but it just crashes. Is this because it's still in beta? Please help.
Opera Mini Next crashes on my Xperia
The Opera Mini Next is crashing probably because it is the beta version. You should download and install the latest full version for Sony Xperia S in order to resolve that issue. If you are comfortable using an alternative browser other than Opera MIni Next, then try that too.
Fletcher Hoss
Hi! Check your Opera Mini if you fully downloaded or not corrupted that and install it without any error encounter. I recommend to download another Opera mini that is compatible with your device. If you encounter the same problem again, install another browser and see this will install completely without any problem. If all browsers you installed encounter the same or different problems, this time you need to consult to Sony Xperia S manufacturer.
