Opera mini for nokia x2 01 mobile phone is not working. I used to open my mobile phone wireless connection to access the internet using opera mini browser, but this time the opera mini is not cooperating it usually stop working and says not responding. How can I be able to fix this issue and enable to use the browser again? Please do help me. Thank you.
Hi Isabella Good day and I have read the complete post from you regarding to your problem facing with your mobile and the browser Operamini is Preinstalled by NOKIA itself and there is no wireless connection feature available for this phone so there may be either problem with your internet connectivity or else you may have a problem with your phone software as it may be crashed due to some error and try to update the mobile through nokia website by connecting it to your cable.
Thanks
Hello Isabella,
You may be getting that issue because the Opera mini browser that you are using is an outdated one. I will therefore suggest that you try updating the browser and then try running it after that and see if it will work. You can as well try an alternative browser that is supported on the nokia phone.
Nicke
