Opera Web browser Bugs and Errors
I have installed the opera web browser. I'm experiencing bugs and errors. How to get rid of this bug and how to report it? Please help. Thanks!
If you are having some problems using Opera browser after you install it, I’m sure this is not an incompatibility issue. Uninstall Opera browser from your computer then check your machine for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, Norton Utilities, or Norton SystemWorks. These are great tools for deep checking your system. These applications can analyze your file system thoroughly. After checking your hard drive, install Opera again. This will fix any corrupted files in the installation and restores its settings back to default. Try browsing some web sites after the installation.
Opera web browser supports Windows, Mac, and Linux operating systems so I’m sure you don’t have an incompatible application. If you are not using the latest version, upgrade to Opera 11.62. Download it from Opera Software’s official web site, http://www.opera.com/.
To download and install Opera Next, please watch this video:
Notifications
