This is a serious problem and I want a good solution.
This error shows when I operate my computer.
Error 1425 – Error Code 0x591
Windows Error Code 1425: 'ERROR_DC_NOT_FOUND'
I cant understand why this error occur. My PC became very slow now a days. I installed AVG virus scanner but also facing updating problem for this error. Lots of important files in my computer and I need to save all the files but failed.
Please suggest me what to do.
jacob.29
Operating system is facing error codes
Hi Kelly Machone,
The error System code 1425 that Displayed "ERROR_DC_NOT_FOUND" is associated with invalid devices.
It's caused by one of those problems :
Windows registry are damaged
Devices conflicts
Damaged in a Hardware
Viruses or Spyware
Software Problem (damaged software)
To resolve this problem please follow my instruction carefully.
Make sure that all your devices drivers have the last update.
You have to use caution when you open attached mails.
Scan your PC for viruses and spyware.
Check your registry errors with a software of Registry checking.
If you still have the same problem I advice you to format your PC because when you have too many software installed in your PC it become very slow and have many problems.
