Operating system with the latest service pack and critical updates
My pc includes all the requirements. In some cases, they are higher than needed. Nevertheless, I am getting the following error message which tells me,
“Minimum System Requirements:
Operating system with the latest service pack and critical updates:
Windows 7 (32-bit or 64-bit edition), Windows Vista (32-bit or 64-bit edition), or windows XP (all edition)
CPU:
Pentium 4 or AMD Athlon 64 (or greater)
RAM: 1GB
Screen Resolution: 1024 x 768”
As a result,the installation process is halted, and I had to use the right up cross button to exit as neither the ‘continue’ nor the ‘cancel’ button works at that moment.
Please give me an effective suggestion. ASAP
