Operating system for my pc
I find a good Operating System for my PC , I think about Microsoft Windows 08 or Mac OS X Lion (version 10.7; marketed as OS X Lion , which is the best Operating System from these two Operating Systems ?
Gmhossain,
These two operating systems have very different options, one is made by Microsoft and the other is by the Apple company. Windows Operating System is super easy to use, and Mac OS is a bit difficult and works only with Apple Mac. You can't install Microsoft Windows on a Mac, I would recommend you use Microsoft Windows 8.
Thanks, and have a great day.
I think for personal use Windows 8 would be the better option. It is easy to use and you can do everything very easily. Linux is definitely faster-booting, but Windows 8 will be the better option if you ask me. You have to get used to Linux, and you need to have experience in Linux before using it. If you are a beginner then it is better to use Windows 8. It is good for media and access to software. I am using Windows 8 myself.
You will get 569 votes for Mac, it is a short form of "Macintosh" and refers to any computers made by Apple, lnc. Its popular applications are iLife, iWork, Xcode, iTunes, Time Machine etc. And you will get 522 votes for the other one. It has Windows, Linux, and Solaris FreeBSD etc. It is cheaper than Mac's hardware.
Thank you for your good realization. Those are good Operating System. Microsoft Windows 8 Operating System has improved tremendously by the features and easiness. I can imagine that you will really enjoy this new Operating System.
On the other hand Mac OS X Lion is good. But it is very difficult to determine which the best Operating System between these two? But it can be said that they are strong competitive. For my side I refer Microsoft Windows 8.
Thank you dear for your thinking. Both are good operating system. Microsoft Windows 8 Operating System has improved tremendously the features. You will really enjoy this new operating system.
On the other hand Mac OS X Lion kept their features constant. It is very difficult to determine which the best operating system is? But it can be said that they are strong competitive. From user point of view I recommend your Windows 8.
