I have purchased a windows 7 operating system dvd and has done my setup but now it is showing as not registered and I cannot find the method to do that. I have been told that the application for registration is inside and now I cannot not find it where. Someone kindly help me with this problem.
Adolfo Brown
Operating system not registered – technical support
I understand your problem. I think you did not register the Windows 7 product after you complete the setup. Every legal software installation needs to be registered with the vendor of the software.
To register your windows 7 operating system right click the “My computer” icon and select the properties in bottom of the menu.
Then it will show you the property window for you.
In the bottom of that window has a category called “Windows Activation”
Under that category you have the option to change your product key.
Using that features you can register the windows 7.
Once you have registered it will show you the windows genuine logo in the right side of the bottom of that property window.
