Hi tech folks,
I am using RhoConnect.NET plugin to connect RhoConnect server for a while. I am getting this error ‘Sync error 422’, when I try to update. How to fix this error? Am I not clear about the error message? Please explain me in detail. Can anyone help me to solve the error? Your help is great. Thanks.
Sync Error
There was an error during sync. Error is The operation couldn’t be completed. (Couldn’t create category error 422.).
The operation couldn’t be completed during Sync
This is a growing issue among iBank users and there is no clear solution on how to fix it. Actually, the “error 422 Sync Error” doesn’t only appear when updating your iBank account using a Mac but will also appear when using and accessing iBank with an iPad. It seems that this synchronization error is a bug in the application.
The best way to fix it is to download and upgrade to the latest version, iBank 5.0.4 for Mac. This version supports Mac OS X 10.8 Mountain Lion and higher and includes a 30-day free trial period. You can find the information on the latest bug fixes in iBank 5 Version History.
If currently you are using iBank 4, you can upgrade to iBank 5 for just $29.99. You just need to download iBank 5, go to “Secure purchase”, and follow the instructions.
