Operations Manager Setup error configuring the operational database
10 points
Posted on - 08/01/2014
Hi there,
SCOM 2012 SP1 install error with SQL 2012 SP1 and before start the install I have checked everything to see if is compatible and if my PC system supports this. Now is there a solution to make the proper install ? Is there a problem with my PC or SQL ?
Thank you !
The installed version of SQL Server is not supported. Verify that the computer and installed version of SQL Server meet the minimum requirements for installation. Please see the Supported Configuration document for further information.
This text has been copied to the clipboard.
