Opinion on choosing other softwares comparable/better than Corel Digital Studio
As a public school librarian, I equipped our library with the present technology by purchasing and using the Corel Digital Studio to create DVDs containing book trailers, photo stories, animottos/videos, and slide shows. It was a decent software and very helpful to the students. I have planned to purchase again for the use of my newly opened school, but I want to ask your opinion if you knew of a comparable/better software than that of the current one I used, which can do stop motion animation. Please help me. I need your advice. Thank you.
Answered By 20 points N/A #100606
Hallo Luisa Labe,
I will advise that you just use the Corel digital studio if it has not let you down so far, for it seems to the popularly used one when it comes to creating DVDs, Videos and so forth, unless you just want to have a taste of the others then you later choose whichever stands out to you.
Other alternative applications that you can use for creating videos apart from the Corel digital studio include:
  • Aquasoft slideshow.
  • Fotomagico.
  • Imagination.
  • Photo DVD Maker.
There are whole lots of others and I will refer you to the following website to preview them and then see which one might interest you.
https://alternativeto.net/software/paint-shop-pro/
Hope this helps.
__
Regards
Mahesh Babu
