I have a server room and it is a 10X10 closet. The room gets heated up. I have heard about sensors that monitor server room temperature. How does server room temperature sensor works? What is the optimal range of server room temperature?
Optimal Temperature Range: Server Room Temperature Sensor.
Server room temperature sensor senses and helps to control server room temperature, preventing failure of the system. It is very necessary to make sure that server room maintains a low temperature.
Server room temperature sensor helps in monitoring the temperature of the server room so that you can take action before failure occurs. You have to make sure that gear in the server room does not fail. A alarm remote containing analog sensors prove to be useful by informing you about server conditions. The server room temperature should not be below 50 degrees Fahrenheit and not more than 82 degrees Fahrenheit.
Working Of Server Room Temperature Sensor
