Hi!
I would like to make it sure that I am working properly with my phone. Give me some pointers on how to maximize its capabilities? What are the possible ways on how to monitor its memory usage? Please provide me also instructions on how to create back up copy for my data? Does it need any software to be installed in the phone? Please provide me alternative solutions for m y problem also so that I will not be confused. Thank you very much and have a nice day!
Optimizing and gaining speed with Android Galaxy S6
Apps you install on your device will run at the maximum speed by default but if you’re using this for a long time, junk files that’re created in your system will slow it down and so, cleaning the junk files is the best way to speed up your phone.
In order to clean those junk files, you can use apps like CCleaner, Clean Master etc. They uses simple tap and clean method without any difficulty or complexity.
Next, update to the latest OTA update. They include many fixes and improvements on performance.
1. Connect your phone to internet.
2. Go to Apps >> Settings >> About device >> Update.
3. Wait until update finishes.
4. Install the update.
Don’t forget to restart your phone sometimes. It’ll speed up your phone.
Get any good security software like Avast Mobile Security, CM Security etc. Update and scan regularly, for example, once or twice a week.
