ORA-00942: Table or View Does Not Exist in OCI
I am getting this dialog box when saving the output from the basic logging while viewing the CDC Instance of the Oracle CDC Designer Configuration tool. This is included in the Change Data Capture for Oracle by Attunity in SQL Server 2012. I Can see the Status on the message or the error box stating a return code 1. What can I do with it?
Status message: The Engine component failed with return code 1. Oracle Call Interface (OCI) method failed: ORA-00942: table or view does not exist.
