Billy Gil
10 points
Posted on - 06/26/2019
I am new to Oracle and I use it every day for my business. Everything is running smoothly and as expected. One day I was doing my normal transactions and the error occurred ora 39170 Schema expression ‘OPS’ does not correspond to any schema. What is this error and how to remove it?
Ora 39170 Schema Expression ‘OPS’ Does Not Correspond To Any Schema
The ora 39170 error is a common error which usually occurs by mistake done by the database user. The ora 39170 Schema expression ‘OPS’ does not correspond to any schema error occurs when the user performs a schema level export but there are special characters in the name of the schema.
There are some solutions for this error but all of them work around accommodating the special character in the schema name. So it is advice not to use special characters in schema names to avoid this error altogether. Some solutions to the error are:
● If there are special characters in the schema name, use \ with any special character while performing the exports.
● Use a parameter file and call it using expdp.
