I need to know how to use the Oracle language and the C++ Programming or it is even possible to use them together.
Oracle on the C++ programming
What you need is a header file named DbManager.h. The iostream.h provide library functions for the input and output stream for use.
#include <DbManager.h>
#include <iostream>
using namespace std;
using namespace oracle::occi;
const string sqlStr("select empname from emp");
const string dateFormat("DD-MON-YYYY HH24:MI:SS");
int main()
// Initialize Services
DbManager* dbm = NULL;
OracleServices* oras = NULL;
Statement *stmt = NULL;
ResultSet *result = NULL;
try
dbm = new DbManager(<Enter the username>);
oras = dbm->getOracleServices();
Connection * conn = oras->connection();
stmt = conn->createStatement(sqlStr);
string empname;
result= stmt->executeQuery();
while (result->next()){
empname = result->getString(1); // get the name
if (result->isNull(1)){
cout << "No Employee”;
cout << empname;
stmt->closeResultSet(result);
conn->terminateStatement(stmt);
delete dbm;
catch (SQLException& ex)
if (dbm != NULL)
dbm->rollbackActions(ex, stmt, result);
catch (ExoException& ex2)
cerr << "nGot Exception:n" << ex2.getExceptionText() << endl;
exit(1);
return 1;
