Oracle DB upgrade pertinent issues.
I would like to upgrade from my Oracle DB from ver. 11.1.0.7 to ver. 11.2.0.3 . Any metalink note that I can consult? I found two (2) notes and they were referring to 11.2.0.2 Interoperability Notes EBS R12 with 11gR2 [ID 1058763.1] database.  Please let me know if there are things to consider before I upgrade from 11.2.0.2 to 11.2.0.3 in relation to Database Performance [ID 1320966.1]. Please inform me if there is any metalink note for 12.1.3 for instance?
Answered By 75 points N/A #98310
Hello Debra Tracy,
The first thing you should put into consideration before you do the upgrade is if the new version that you are switching to is compatible to the version of the operating system that you are using, so that you end up upgrading and then find the upgrade does not meet the system requirements of your computer system.
Also check for the ease of use of the version that you want to switch and the functionalities it offers as compared to the old version. I am sure you will not like switching to a new oracle server and then find out that it is complicated to use or it misses some functionalities that were present in the older version.
Hope this helps.
__
Regards
Lee Hung
