Oracle DB ver. 10.2.0.5 upgrade concerns.
 My Oracle 10.2.0.5 database test version is running on Windows 7 and has 11g grid control's storage area and the agent is also 11g. My concerns are:
Hello Emily Rays,,
You can try using the usual way of upgrading the database, and that I guess is by automatically updating the database from online, and see if it will work that way. I doubt if there grid controls may be affected when you upgrade the database that way, unless the process of upgrading itself ends up having some problems that might lead to that happening.
In case upgrading online, you might just consider getting the new version of the database that you need to switch and then manually run it to install it on your system. This way too will retain the grid control as they are but you may need to do configuration like setting the system passwords.
__
Regards
Lee Hung
