Hi dear,
I am receiving this error. Please provide me its solution. How can I remove this error.
Details of Error:
Error in invoking target install of makefile/user/ora9/product/9.2/network/lib/ins_oemagent.
Mk
Press ‘Help’ for more information.
Press ‘Retry’ to try again.
Press ‘ignore’ to ignore this error and go on.
Press ‘Cancel’ to stop this installation
Help Retry Ignore Cancel
Thanks in advance.
Oracle Error in invoking target
Hi Jess,
Your problem was in your system. It seems that your system was not able to install the application you want because of lack of space in your hard drive. I suggest before you install that program, check the availability of your hard drive, if you have enough space on it. You can remove some files that you are not using in your system.
Also you can use the program installed in your system the “Dick CleanUp”. So you have a free space and defrag to compress some of your files. Then try installing your application. If the problem persists, contact the application administrative for further information about your problem.
Thanks
