I need your help on this problem that arose after I installed Oracle 10g database software on local disk D in my pc that runs on windows 7. The problem is that I get errors telling me permission denied when I tried creating a database. I don’t get this since I enabled “run as administrator privilege” during installation.
What should I do next?
Oracle problems in creating database with windows7
I have studied Oracle 9i and we used to get the same error as you are. But I might be in a doubt that the same method will be used for tackling the same problem in Oracle 10G. However it is best for you if you can install a virtual machine windows XP and use the oracle 9i in it. But lets try to figure out the issue.
There is something that needed to be changed in the physical directory where the oracle is installed. That is why the run as administrator option is not functioning properly.
First make sure that you are logged in as the same user that installed the oracle on the computer.
Try to run the following code by putting your username and password
Enter user-name: scott/tiger@claimdb
Connected to:
Oracle 8i Enterprise Edition Release 8.1.7.4.0 – Production
With the Partitioning option
JServer Release 8.1.7.4.0 – Production
There is also a video that might help you get out of this problem.
