Oracle server error while connecting at localhost
Invalid connect appears every time when I try to connect to Oracle server. I have checked my Internet connection and is working fine like usually. Does any of you experts have some free time to help me with this error ? What I did wrong ?
Thanks !
Invalid Connect
UPGAST – 00014: Unable to connect to WebLogic Server at localhost: 7001
T3://localhost:7001: Destination unreachable; nested exception is: java.net. ConnectException: Connection refused; No available router to destination
Answered By 0 points N/A #178319
At first you should check the doc ID 1311489.1
The doc solutions will be:
Configure a Network Channel
1.Configure a network channel for localhost [WebLogic Admin console > log in as Administrator].
2. Servers > Protocols > Channels.
3.Click on "Configure a new Network Channel,"
4.Configure the network channel as follows. [You may change the name of the channel]
 ◦Name: Loopback
â—¦Protocol: t3
â—¦Listen Address: localhost
â—¦Listen Port: 7001 [same as Admin server host]
Create the network channel.
5. Shut down and restart the server.
6.Look in the WebLogic log for a successful ping message:
<Mar 29, 2011 6:14:01 PM EDT> <Notice> <WebLogicServer> <BEA-000355> <Thread "ListenThread.Loopback" listening on port 7001, ip address 127.0.0.1>
Configure WLS 8.1 For Default
NOTE: This is for WLS 8.1 only.
You may take a test by doing:
1.In the console, navigate to <server> -> Configuration -> General -> Listen Address.
2.Remove any entry for parameter "Listen Address."
3.Apply changes.
4.Restart the WebLogic instance.
Now you can access the application with all DNS names/IP addresses which are associated with the machine. You can also use the loopback address for the weblogic.Admin PING utility. The WebLogic instance will listen on loopback address – either localhost or 127.0.0.1.
