Hi dears,
I am trying to install Oracle at my system during installation i am receiving this error.
Error
OUI-25031: Some of the configuration assistants failed. It is strongly recommended that you retry the configuration assistants at this time. No successfully running any “Recommended” assistants means your system will not be correctly configured.
Check the Details panel on the Configuration Assistant Screen to see the errors resulting in the failures.
Fix the errors causing these failures.
Select the failed assistants and click the ‘Retry’ button to retry them.
OK
alex don
Oracle Universal Installer Configuration Assistants.
Actually this is an error, which is not in your program names oracle but here there is a problem of a support from your computer side towards that software and for that there is a need to correct your computer configuration setting, up to that level which is required for that software.
This thing is very simple to know. First of all, you can open the configuration or requirement of that Oracle software and then see what it requires and then again go to the system configuration. I am talking about your PC's configuration and then match those configuration with the requirements of your Oracle program, then if there are things which are not matching, then first install those and then retry that software installation.
Cheers.
